  #24
Old 08-30-2005, 04:11 AM
sjroorda sjroorda is offline
Originally posted by farshizzo
The Vizard network commands use a datagram socket on port 4950 to communicate.
Again a subtile kick! I need to send this data to two different Vizard-instances on the same computer. Creating a UDP-socket works great for one of them, but the other never receives any data. I guess this has to do with the fact that at the moment the first instance catches the data, this UDP-packet is gone.
A trivial solution for this would be connecting a second socket to a different port, but I can nowhere find a way to specify the port number!
Is this possible, is there another way, or should I look for a completely different workaround?
