Old 03-12-2015, 09:46 AM
Try using the following code to see what the contents of the raw_data attribute is:
def onNetwork(e):
    if isinstance(e,viz.RawNetworkEvent):
        print repr(e.raw_data)
Keep in mind that the raw data can contain trailing NULL (\x00) byte values, so you might need to account for this if you are expecting to receive a string.
