Old 02-23-2015, 08:45 AM
willpower2727 willpower2727 is offline
Ok here is a slightly simplified version of my code, however I doubt anyone else will be able to run it due to the lack of having all the dependencies.
import socket
import sys
import io
import re
from xml.etree import ElementTree
import threading
import Queue
import time
import json
#initialize objects
global scalorxx
scalorxx = 0.6667
global targetL
targetL = 1
global targetR
targetR = 1
global targettol
targettol = 0.05
global boxL
boxL = viz.addChild('target.obj',color=(0.063,0.102,0.898),scale=[0.1,(targettol+0.04)*0.75,0.0125])
boxL.setPosition([-0.2,targetL*scalorxx,0])
global boxR
boxR = viz.addChild('target.obj',color=(0.063,0.102,0.898),scale=[0.1,(targettol+0.04)*0.75,0.0125])
boxR.setPosition([0.2,targetR*scalorxx,0])
global cursorR
cursorR = viz.add('box3.obj', color=viz.RED, scale=[0.1,0.1,0.0125], cache=viz.CACHE_NONE)
cursorR.setPosition([0.2,0,0.05])
global cursorL
cursorL = viz.add('box3.obj', color=viz.GREEN, scale=[0.1,0.1,0.0125], cache=viz.CACHE_NONE)
cursorL.setPosition([-0.2,0,0.05])
global HistBallR
HistBallR = viz.add('footprint2.obj', color=viz.YELLOW, scale=[0.03,0.03,0.1], cache=viz.CACHE_NONE)
HistBallR.setPosition([0.2,targetR*scalorxx,0])
HistBallR.setEuler(0,0,0)
HistBallR.alpha(0.8)
global HistBallL
HistBallL = viz.add('footprint2.obj', color=viz.YELLOW, scale=[0.03,0.03,0.1], cache=viz.CACHE_NONE)
HistBallL.setPosition([-0.2,targetL*scalorxx,0])
HistBallR.setEuler(180,0,0)
HistBallL.alpha(0.8)
viz.MainView.setPosition(0, 0.5, -1.5)
viz.MainView.setEuler(0,0,0)
global histzR
global histzL
histzR = 0
histzL = 0
global rstridetime
global lstridetime
rstridetime = 0
lstridetime = 0
#global RHS
#global LHS
#RHS = 0
#LHS = 0
global FNold
FNold = 0
#definition for the first thread
def UpdateViz(root,q,savestring,q3):
	timeold = time.time()
	RHS = 0
	LHS = 0
	while not endflag.isSet():
		global targetR
		global targettol
		global histzR
		global histzL
		global rstridetime
		global lstridetime
#		print(Queue.Queue.qsize(q))
		root = q.get()#look for the next frame data in the thread queue
		q.task_done()
		timediff = time.time()-timeold
		lp1 = root.find(".//Forceplate_0/Subframe_9/F_z")#Left Treadmill
		rp1 = root.find(".//Forceplate_1/Subframe_9/F_z")#Right Treadmill
		temp = rp1.attrib.values()
		Rz = float(temp[0])#cast forceplate data as float
		temp3 = lp1.attrib.values()
		Lz = float(temp3[0])
		cursorR.setScale(0.1,rstridetime*scalorxx,0.01250)
		cursorL.setScale(-0.1,lstridetime*scalorxx,0.01250)
		#check for gait events
		if (Rz < -30) & (histzR >= -30):#HS condition
			HistBallR.setPosition([0.2, rstridetime*scalorxx, 0])
			RHS = 1
			if (abs(rstridetime-targetR) <= targettol):
				boxR.color( viz.WHITE )
				boxR.color( viz.BLUE )
			rstridetime = 0
			rstridetime = rstridetime+timediff
			RHS = 0
		if (Lz < -30) & (histzL >= -30):
			HistBallL.setPosition([-0.2, lstridetime*scalorxx, 0])
			LHS = 1
			if (abs(lstridetime-targetL) <= targettol):
				boxL.color( viz.WHITE )
				boxL.color( viz.BLUE )
			lstridetime = 0
			lstridetime = lstridetime+timediff
			LHS = 0
		histzR = Rz
		histzL = Lz
		#send some data to be saved
		fn = root.find(".//FrameNumber")#Left Treadmill
		fnn = fn.attrib.values()
#		print(fnn[0])
		savestring = [int(fnn[0]),Rz,Lz,RHS,LHS]
#		print(sys.getsizeof(savestring))
		q3.put(savestring)
#		print(q3.qsize())
	q3.join()
	print("data has all been gotten")
#definition of tcp thread
def runclient(root,q):
	#illegal characters to remove from string later before going to xml
	RE_XML_ILLEGAL = u'([\u0000-\u0008\u000b-\u000c\u000e-\u001f\ufffe-\uffff])' + \
					 u'|' + \
					 u'([%s-%s][^%s-%s])|([^%s-%s][%s-%s])|([%s-%s]$)|(^[%s-%s])' % \
					  (unichr(0xd800),unichr(0xdbff),unichr(0xdc00),unichr(0xdfff),
					   unichr(0xd800),unichr(0xdbff),unichr(0xdc00),unichr(0xdfff))
	HOST = 'localhost'#IP address of CPP server
	PORT = 50008
	s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
	print 'Socket created'
	print 'Socket now connecting'
	s.connect((HOST,PORT))
	s.send('1')#send initial request for data
		global FNold
		data = s.recv(50)#receive the initial message
		data3 = data[:3]#get first 3 letters
		if (data3 == "New"):
			nextsizestring = data[3:]#get the integer after "New"
			nextsizestring2 = nextsizestring.rstrip('\0')#format
			nextsize = int(nextsizestring2,10)#cast as type int
#			print("Next Packet is size: ")
#			print(nextsize)
			s.send('b')#tell cpp server we are ready for the packet
			databuf = ''#initialize a buffer
			while (sys.getsizeof(databuf) < nextsize+21):
				data = s.recv(nextsize)#data buffer as a python string
				databuf = databuf + data#collect data into buffer until size is matched
#			print(sys.getsizeof(databuf))
			root = ElementTree.ElementTree(ElementTree.fromstring(databuf))#create the element tree
			q.put(root)#place the etree into the threading queue
			FN = int(fnn[0])
			if (FN - FNold >= 20) & (FNold != 0):
				print("gap larger than 20 has occured")
			FNold = FN
		elif (data3 != "New"):
			print("WARNING! TCP SYNCH HAS FAILED")
			break
		if not data: break
		s.send('b')
	s.close()
	q.join()
#thread that saves data (no problems here)
def savedata(savestring,q3):
	#initialize the file
	mst = time.time()
	mst2 = int(round(mst))
	mststring = str(mst2)+'StrideTime.txt'
	print("Data file created named:")
	print(mststring)
	file = open(mststring,'w+')
	json.dump(['FrameNumber','Rfz','Lfz','RHS','LHS'],file)
	file.close()
	file = open(mststring,'a')#reopen for appending only
	print('file is open for appending')
#		print(q3.empty())
		savestring = q3.get()#look in the queue for data to write
		print(savestring)
		q3.task_done()
		if savestring is None:
			continue
			json.dump(savestring, file)
	print("savedata stop flag raised, finishing...")
	while 1:
		try:
			savestring = q3.get(False,2)
		except:
			savestring = 'g'
#		print(savestring)
		if savestring  == 'g':
			break
			print("data finished write to file")
			print("data still writing to file")
	print("savedata finished writing")
	file.close()
#event callback when user presses 'q'
endflag = threading.Event()
def raisestop(sign):
	print("stop flag raised")
	endflag.set()
	t1.join()
	t2.join()
	t4.join()
	viz.quit()
root = ''#empty string
savestring = ''
q = Queue.Queue()#initialize the queue
q3 = Queue.Queue()#intialize another queue for saving data
#create threads for client
t1 = threading.Thread(target=runclient,args=(root,q))
t2 = threading.Thread(target=UpdateViz,args=(root,q,savestring,q3))
t4 = threading.Thread(target=savedata,args=(savestring,q3))
t1.daemon = True
t2.daemon = True
t4.daemon = True
#start the threads
t1.start()
t2.start()
t4.start()
print("\n")
print("press 'q' to stop")
print("\n")
vizact.onkeydown('q',raisestop,'t')
