Old 02-18-2015, 06:26 AM
Are the images on both walls matching up and synced with each other? If so, then it sounds like you have the cluster setup properly. The double image maybe due to inverted stereo. On that machine you can go into the nvidia control panel under 'Manage 3D settings'. Try changing the 'Stereo - Swap Eyes' setting.
