Old 08-26-2005, 01:12 PM
There are many ways to do this. You can get the duration of the animation and then setup a timer to go off in that time. Or you can use callbacks to detect when the action has finished. Here's an example of using the callback method:
male = viz.add('male.cfg')
male.translate(0,0,5)
action2 = vizact.animation(2)
male.add(action2)
def actionend(obj,action,pool):
	if action == action2:
		print 'Action 2 is finished'
male.callback(viz.ACTION_END_EVENT,actionend)
