Viz PPT 1 problems
I am having problems with a Viz PPT 1 tracking system.
The system says that the position of the LED is jumping all over the place, when in a VIZ script.
The PPT interface, however shows the LED being tracked constantly.
I have made sure that there are no errant sources of light in the room and adjusted the threshold and gain settings in my curcal file.
None of these things has helped the situation.
I have also hooked up the camera feeds to external monitors, looing for dead pixels - to no avail.
Do you have any other suggestions as to what may be causing this type of behavior?
