Old 01-22-2015, 05:28 AM
On the VRPN client side, you need to specify the marker ID number assigned to the Wand in PPT, the PPT IP address or name, and port 8945. You must specify port 8945 since the Wand data is sent through a different port than the default VRPN port. For example, if the wand is marker ID '3' and the machine name is 'PPT_MACHINE' the following would be used in Vizard to get the data via VRPN:
joystick = vrpn.addAnalog('PPT_WAND3@PPT_MACHINE:8945')
button = vrpn.addButton('PPT_WAND3@PPT_MACHINE:8945')
