To send objects across the network you will need to use the Python
pickle module. This module will serialize any object into a string, and can recreate it. Here is some code that will take an object and serialize it to a string:
	import pickle
s = pickle.dumps(obj)
 The following code will convert a pickle string into an object:
	import pickle
obj = pickle.loads(s)
 Let me know if you need more help
