Old 11-25-2014, 10:01 AM
Here is a sample script that will save the raw image data of the screen to a base64 encoded file when the spacebar is pressed:
import viztask
import base64
model = viz.addChild('maze.osgb')
def SaveScreenTask():
	while True:
		# Wait for key press
		yield viztask.waitKeyDown(' ')
		# Capture screen to texture
		texture = viz.addBlankTexture([1,1])
		viz.window.screenCapture(texture)
		# Wait a frame for image to be captured
		yield viztask.waitFrame(1)
		# Save raw texture data to base64 encoded buffer
		data = base64.b64encode(texture.saveToBuffer('<raw>'))
		# Save data to file
		with open('screen_data', 'wb') as f:
			f.write(data)
		# Remove texture
		texture.remove()
viztask.schedule( SaveScreenTask() )
