Old 11-13-2014, 06:44 AM
rmcconnell11 rmcconnell11 is offline
Ok back to having the same/similar problem.....
So gloves work perfect on the vizsetup file. To create my virtual world I use viztracker, which then uses vizsetup.... without changing any thing if i run the script...it won't connect to the gloves
** ERROR: Failed to connect to 5DT glove on COM1
Then if I put the port definitions and glove additions into the create composite command in vizsetup, same error
So now i have tried defining the ports and adding the gloves in the main script, but for some reason it has went back to reading only one glove for both hands
