Old 11-11-2014, 04:52 PM
Try adding two 5dt data glove inputs in Vizconnect and save the configuration file. It's fine if only one shows a connection at this time. Close down Vizconnect and open the config file in the Vizard GUI and find the initInputs section. You'll see code for data_glove and data_glove2. In the data_glove2 section change:
__main__.PORT_5DT_USB = 0
to:
__main__.PORT_5DT_USB = 1
Then run the config file and see if both gloves connect.
