Old 11-11-2014, 04:19 AM
rmcconnell11 rmcconnell11 is offline
Hi Jeff,
Thanks for the reply. I will try your suggestions after lunch Although I have tried using vizconnect, the problem I seem to be having is that Vizard doesn't recognize the two gloves separately.
For example, I connect the right hand on it's own and the fingers move as mine move. I connect the left hand on it's own and the fingers move as mine move. I connect both together and depending on the last port defined both hands move together. I don't even change the USB Ports that were defined for the individual gloves, and if I use the tutorial for the 5DT glove then they will move separately.
