hi Jeff,
a few details about the test/problem - i am getting towards the wall until collision. then i try to advance oblique against the wall. what i expect is to slide along. instead i slide and bounce at the same time. it happens on the whole length of the wall, as long as the wall is not parallel with one of the axis.
i already did try to change the collision buffer, but with no success. did it work for you? with what value?
