Old 10-31-2014, 06:41 AM
andreionutz andreionutz is offline
me again.
i stripped down my code to the very basic and still didn't find a solution. i can't see how anything could be wrong in the usage, but i posted the code below anyway. i also tried different models from 3D Warehouse and i could reproduce the problem.
attached is a very simple collada model i generate myself(rename to .dae). the normals are ok, but i still have the bumping effect when the wall is oblique. i think the problem is somewhere in the Vizard navigation code and has something to do with vector decomposition, otherwise i cannot explain why it's not happening when the wall is parallel with an axis...
viz.setOption('viz.model.apply_collada_scale',1)
world = viz.addChild('.\\..\\configs\maze3D.dae')
world.collideMesh()
env = viz.addEnvironmentMap('sky.jpg')
sky = viz.addCustomNode('skydome.dlc')
sky.texture(env)
viz.disable(viz.LIGHTING)
viz.MainView.collision(viz.ON)
viz.MainView.setPosition(3.02036, 0.00000, -0.08363)
viz.MainView.eyeheight(0.11)
