Old 10-24-2014, 09:49 AM
mape2k mape2k is offline
Question about postScale while linking two objects
Hello all,
here is what I want to achieve:
Link an object (destination) to the viewpoint (source), so that it moves with the viewpoint BUT at a different speed. E.g. if the viewpoint moves 10m, the linked object should only move 2m.
I managed to do that with the postScale command. However, the scaling is also applied to the inital offset of the destination object. This is a problem, because I want to destination object to start out at a certain offset, independent of the speed scaling.
I tried to manually set a transformation matrix but failed so far. I included a small sample script. Here, the pigeon starts out at an offset of [3,0,3] from the viewport. I want it to move with the viewport, but at a different speed.
If I apply a postScale, the pigeon will NOT start out at an offset of [3,0,3], but at the offset multiplied by the scale.
model = viz.add('pit.osgb')
pigeon = viz.addAvatar('pigeon.cfg')
pigeon.setScale(3,3,3)
# with linking
pigeonlink = viz.link(viz.MainView, pigeon, offset = [3,0,3], mask = viz.LINK_POS)
postScale = pigeonlink.postScale([0.8,0,0.8], target = viz.LINK_POS_OP)
viz.setMultiSample(8)
viz.fov(90)
Thanks for your help in advance!
