Old 10-14-2014, 09:37 AM
Not sure what seem to be the problem, but I noticed that you want to write declaration to the question_data file. However, I don't see any variable called declaration. Furthermore, the write command is capable of writing multiple lines at the same time, so it would be more efficient to create one string, and writing that one string with a write statement.
Could you clarify what exactly seems to be the problem? Have you tried writing simple information to a .txt file instead of an .xml? I know they are basically the same, but I don't know of the write command handles .xml files well. Furthermore, the program could get stuck in a loop with the while command. Replace the while loop with an if statement. If that does not solve your problem, please specify your problem.
