Old 09-30-2014, 05:21 PM
Melody Melody is offline
Originally Posted by Jeff View Post
You could try removing the on-the-fly object and starting a new one.
It seems like the on-the-fly object is always a global one. I cannot create local on-the-fly-object. Actually, the function I wanna realized is to delete the graph and then continue creating. When I tried to use remove, the graph seems no longer visible.
Btw, if I upgrade vizard from 3.0 to 4.0 or 5.0. Is any compatibility problem going to happen? Can I still run phantom omni in it?
