Old 08-27-2014, 03:31 PM
Kevin Chiu Kevin Chiu is offline
No, I have tested them all on 3.0, 4.0, 5.0 already. It should work right away.
Can you confirm that the example scripts runs with out problem and works fine first on your end?
What is the error message you got?
For me it seems there might be just something wrong in your code.
For example the parameter you passed to the callback doesn't seems legal at least.
Shouldn't it be a BUTTONDOWN_EVENT instead of passing the button directly?
