Thread: vicon.dle error
Old 08-22-2014, 08:00 AM
Unless you're using an older version of Nexus it's likely the streaming protocol is not compatible with the Vizard plug-in.
Do you have Vicon Tracker? If so you could use VRPN to stream the data to Vizard. The last time I checked Nexus did not support VRPN. You might ask Vicon support to see if that's changed.
