Old 08-19-2014, 07:56 PM
If you want to show one object from different viewpoint locations then you need to have a separate viewpoint for each window and change the viewpoint position/orientation.
If the viewpoint location is the same for all windows but you want to have one object showing up in different positions in that view you can add the model 4 times. Each model can then be rendered to a single window using renderOnlyToWindows.
