the Intersense server application or service could still be running -
if it was running during your uninstall, it's possible that it did not uninstall correctly. it usually shows up in the lower right part of the start bar as an icon, and you can click on it and disable it there.
to see if a process is still running, check processes with ctrl-alt-del and search for iserver or similar. you can kill the process right there.
