Thread: VizTouch Help!
Old 08-14-2014, 05:10 AM
Majestic12 Majestic12 is offline
VizTouch Help!
Hello!
First of all I would like to say thank you for a wonderful software. I have had hours of fun creating various virtual environments.
I have just recently purchased a touch-screen and started exploring the VizTouch module and I have a little issue, maybe you can help!
I have a cube that I want to look around using setEuler. I disabled the regular mouse navigation but I can't seem to figure out how to determine which way I want to rotate. In terms of touch I want this:
def begin(e):
#Begin touch
def move(e):
#On move, determine which direction it is moving and rotate the around the
cube appropriately. As long as the touch persists, keep rotating slowly.
def end(e):
#End touch
viztouch.onTouchDown(begin)
viztouch.onTouchMove(move)
viztouch.onTouchUp(end)
I tried to do a similar thing with the gestures, but it turned out fairly clunky. I had to do flicks repeatedly and each time would move the view a fixed distance:
def gesturemethod(typen):
if (typen == 'left'):
     #cube.setEuler...
elif (typen == 'right'):
     #cube.setEuler...
elif (typen == 'up'):
     #cube.serEuler...
elif (typen == 'down'):
     #cube.setEuler...
viztouch.onGestureFlick(viztouch.FLICK_UP,gesturemethod, 'up')
viztouch.onGestureFlick(viztouch.FLICK_DOWN,gesturemethod, 'down')
viztouch.onGestureFlick(viztouch.FLICK_RIGHT,gesturemethod, 'right')
viztouch.onGestureFlick(viztouch.FLICK_LEFT,gesturemethod, 'left')
I would like to do a smooth solution with the touch one but I can't seem to figure out how to do it smoothly. I would be appreciative of any help I can get in this! How do I determine which way a touch is moving and then set the euler accordingly?
Thanks!!
M12
