Old 08-12-2014, 01:05 PM
The 64-bit version uses a different API to connect to the FasTrak, since the original API only supports 32-bit. So there may be a bug in their new API. I've tested a USB FasTrak with 64-bit Vizard here, and it connects fine.
Are you able to connect to the FasTrak using the Polhemus PiMgr application? You might need to install the new USB drivers for it to work with the new API.
