Polhemus FasTrak Error Message
I get the following Error message in Vizard 5 Beta 4 when I try to connect a Polhemus FasTrak via USB
** ERROR: Failed to connect to a FasTrak: S : Device not found
** ERROR: Failed to create extension sensor with polhemus.dle
I tested the same Polhemus FasTrak via USB under Vizard 4 and it looks to work fine:
polhemus.dle Polhemus Extenstion
1 station(s) detected
** NOTIFY: Connected to Fastrak over USB Connection
I was able to connect a Polhemus Patriot correctly using Vizard 5 Beta 4
Has anyone tested a Polhemus FasTrak via USB with Vizard 5 Beta 4?
Any idea what the issue might be?
Thank you
John
