Thank you for replying my message Jeff.
I want to be able to use my joystick to navigate the vizard virtual environment. For example, if I push the joystick up/down, it should move forward/backward on the screen, and if I push it sideward, it should move either left or right, depending on where I'm moving the joystick. I also want to balance the screen positioning too because, if I wear my shutter glass (head tracker) the screen is not balance. Thank you.
