Old 07-30-2014, 03:28 PM
No, if the viewpoint is offset from the wheelbarrow the viewpoint collision won't work here. You can control the wheelbarrow directly and link the viewpoint to it with an offset. The wheelbarrow's height has to be manually adjusted each frame according to the height of the ground to go up the ramp. You can use the viz.intersect command to help determine the height of the ground.
