Old 07-24-2014, 02:19 PM
Daniel1 Daniel1 is offline
Exclamation
Hello Jeff,
Thanks for your reply. I did all you ask me to do according to the link provided, and I also tried to add wand tracker to it with the code bellow, but it's gave me an error. Please I need your help again. How can I solve this error problem? ERROR: Failed to create extension sensor with intersense.dle
code:
viz.setMultiSample(4)
vizconnect.go('vizconnect_config.py')
PORT_INTERSENSE = 3
isense = viz.add ('intersense.dle')
tracker = isense.addTracker(port =3)
tracker1 = viz.add('intersense.dle')
#keyTracker = vizconnect.getTracker('keyboard').getNode3d()
tracker0Tracker = vizconnect.getTracker('tracker0').getNode3d()
import vizshape
axes = vizshape.addAxes()
#viz.link(keyTracker,axes)
viz.link(tracker0Tracker,axes)
The errors are:
** ERROR: Failed to connect to Intersense tracker on port 3
** ERROR: Failed to create extension sensor with intersense.dle
File "<string>", line 11, in <module>
File "C:\Documents and Settings\STUDENT\Desktop\Displays and tracker\dispalys_trackers_tutorial.py", line 14, in <module>
File "C:\Program Files\WorldViz\Vizard5\python\vizconnect\__init__. py", line 2152, in getTracker
return getNode(classification=CLASS_TRACKER, name=name)
