Old 07-17-2014, 06:43 AM
mshukun mshukun is offline
Thank you so much. It worked perfectly. I created the application that also produce CSV file using Vizard 4.0 in the past. For that application, I used 'os.getcwd()' function and didn't have any problem producing a CSV file so I assumed it should work the same on Vizard 5 beta. I should have checked the Vizard module reference one more time before posting the question. Again, thank you so much for your quick response!!
