The Intersense products come with an installation CD that typically installs the Intersense server application. If configured correctly, the Intersense Server works directly with Vizard and you should not get such an error message. Most likely, you did not yet set up the Iserver correctly.
Vizard supports Intersense product with a native driver, therefore the Iserver software is not needed for Vizard to support the InertiaCube.
You now have two options to get your system working:
A) uninstall the Intersense server application and the Intersense drivers. Then Vizard will use it's built-in driver and will work.
B) configure the Intersense Server application correctly, so it recognizes and connects to the IC2.
Have fun!
The WorldViz Team
