Old 07-15-2014, 06:12 PM
Vizconfig panels support text boxes that filter for float or int values. Would this work for you?
Press F12 to toggle the visibility
of the configuration window
import vizconfig
import vizinfo
viz.setMultiSample(4)
viz.fov(60)
vizinfo.InfoPanel()
gallery = viz.add('gallery.osgb')
value = 25.0
def getValue():
	return value
def setValue(v):
	value=v
#Create a configurable object
bc= vizconfig.BasicConfigurable('Enter a float value between (-50,50)')
bc.addFloatItem('float value',range=(-50,50),fset=setValue,fget=getValue)
#register the object so it will display in the configuration window
vizconfig.register(bc)
