Old 07-07-2014, 12:06 PM
Problem solved, thanks to the persistence of a wily grad student and a lengthy back and forth with Jeff. Thanks again, Jeff! You're always a huge help.
To those having similar issues:
It turns out that our projector's listed specs were inaccurate, and it did not accept a listed 3D format. This is BenQ's fault. So, we abandoned the use of DLPLink on our Geforce card, and instead got things to work using a Quadro card using the Quad_Buffer option.
Just FYI, to enable quad buffering, we had to go into nVidia control panel and enable stereo mode for "winviz.exe" and not "Vizard.exe".
Info. summary in case anybody runs into the same trouble:
1. BenQ MW870UST 3D DLP link projector.
**Set at a resolution supporting 120Hz.**
2. Generic active shutter glasses.
3. nVidia Quadro 4000
4. Vizard 5 32 bit
i. Run and close application once to register with "nVidia Control Panel" automatically.
ii. If "winviz.exe" does not automatically populate itself on "nVidia Control Panel -> Manage 3D settings",
click on add and navigate to Vizard's installation directory and select "winviz.exe".
iii. Enable stereo mode for "winviz.exe".
5. Run code with the "viz.QUAD_BUFFER" flag.
