Old 07-01-2014, 06:52 PM
The intersection test returns the lowest level sub-node in the scene hierarchy. To determine the name of the node above the geometry node set computePath to True when you call the viz.intersect command. The name_path attribute of the returned viz.Intersect object contains a list of sub-node names representing the full path to the intersected object within the scene hierarchy.
