Old 06-28-2014, 07:16 AM
armo armo is offline
Problems with avatars facial expressions exported with Cal3D
Hi all,
I am working with the Vizard Complete Characters library and I would like to import into vizard an avatar with a painful facial expression. I modeled this expression in 3DS max and exported it following the instructions of the CAL3D tutorial but I had the strange results you see in the attached screenshots.
Furthermore vizard sends me this error:
Loading File: casual02_m_highpoly_Expressions/casual02_m_highpoly_painful.cfg
** WARNING: Failed to load animation file: male_high_pain.CAF
Warning: Material::setShininess() of 6400 is above permitted maximum, clampping to 128.
** Load Time: 0.12 seconds
Could you please tell me where is the error?
Here's the source code:
viz.MainView.setPosition( 0, 1.5, 0 )
av_painful = viz.add('casual02_m_highpoly_Expressions/casual02_m_highpoly_painful.cfg', pos=( 0, 0, 1.5 ), euler=(180,0,0))
neutral = vizact.morphTo( 0, 0, 1 )
pain = vizact.morphTo( 0, 1, 1 )
wait = vizact.waittime(vizact.randfloat(1,5))
action = vizact.sequence( wait, neutral, pain, viz.FOREVER )
av_painful.addAction(action)
and here's the .cfg file:
# Cal3d cfg File
scale=0.01
flip_texture = 1
################# Skeleton #################
skeleton=male_high_Skeleton.CSF
################# Meshes #################
mesh=casual02_m_highpoly.CMF
morph=casual02_m_highpoly_pain.CMF
mesh=casual02_m_highpoly01.CMF
################# Animations #################
animation=male_high_pain.CAF
################# Materials #################
material=casual02_m_highpoly.CRF
material=casual02_m_highpoly01.CRF
thank you very much,
armo
ID:	656   Click image for larger version
