				 animate an object using 5dt data glove 5 ultra
			hi;
 I have to animate i.e, control the motion of an object using data glove.
 I tried grabbing the object , but now i dont know how should i try moving the object in accordance to my glove. I am posting the code below:
 import vizcam
 import random
 import hand
 viz.setMultiSample(4)
 viz.fov(60)
 #viz.go(viz.QUAD_BUFFER)
 #viz.go(viz.HALF_RESOLUTION)
 PORT_5DT_USB = 0
 sensor = viz.addSensor('5dt.dls')
 glove = hand.add(sensor,hand.GLOVE_5DT)
 vase = viz.add('vase.ive')
 vase.setPosition(-160,40,-30)
 models={'9.ive'}
 model1=viz.add('9.ive')
 viz.MainView.setPosition(-160,50,130)
 viz.MainView.setEuler(180,00,0)
 gestureName = ['Fist', 'Index finger point', 'Middle finger point',
 'Two finger point', 'Ring finger point', 'Ring-Index finger point',
 'Ring-middle finger point', 'Three finger point', 'Little finger point',
 'Index and little finger point', 'Little-middle finger point',
 'Not ring finger point', 'Little-ring finger point',
 'Not middle finger point', 'Not index finger point',
 'Flat hand', 'Undefined']
 def getGesture():
 gesture = int(sensor.get()[-1])
 if gesture == 7:
 #three finger
 viz.MainView.setPosition([0,0,0.05],viz.REL_PARENT)
 if gesture == 8:
 #Little finger point
 viz.MainView.setPosition([-0.05,0.0,0],viz.REL_PARENT)
 if gesture == 9:
 #Little finger and index point
 viz.MainView.setPosition([0.05,0.0,0],viz.REL_PARENT)
 if gesture == 3:
 #two finger point
 viz.MainView.setPosition([0,0.0,-0.05],viz.REL_PARENT)
 if gesture == 1:
 #Index finger point
 viz.MainView.setPosition([0,.05,0], viz.REL_PARENT)
 if gesture == 0:
 #Fist
 #vase.setPosition([0,-.05,0], viz.REL_PARENT)
 viz.MainView.setPosition([0,-.05,0], viz.REL_PARENT)
 if gesture == 14:
 viz.link(glove,vase)
 viz.grab(glove,vase)
 vizact.ontimer(0, getGesture)
