Old 06-13-2014, 12:46 PM
Vizconnect SpaceGrip problem
I'm trying to use the Laseraid SpaceGrips as an Input in the Vizconnect interface but it doesn't look like it is working correctly. The Status shows a green light like it is working but this shows whether the SpaceGrips are connected to my computer or not.
I noticed that the SpaceGrips are connecting via Port 5 (COMM5) and it looks like the default is Port 1. There doesn't seem to be any way to change the Port # in Vizconnect.
I did use the Example code you had in the Reference Section under Gaming Devices -> Laseraid SpaceGrips and the SpaceGrips work fine using the Example Code.
Checking to see if there is anything I can do to get the SpaceGrips working in Vizconnect?
thank you
John
