Old 06-11-2014, 09:20 AM
mshukun mshukun is offline
Oculus <hmd>.addMessagePanel
Thank you very much for adding Oculus addMessagePanel in the Vizard 5!! I have a couple of questions regarding "addMessagePanel".
Q1: Can I change message in the "addMessagePanel" without removing and recreating "addMessagePanel" object (e.g. info_panel.message("Hello"))?
import viztask
import oculus
questions = ["Q1:", "Q2:", "Q3:"]
hmd = oculus.Rift()
viz.link(hmd.getSensor(), viz.MainView)
def test():
    for index in range(len(questions)):
        if index <= len(questions):
            yield viztask.waitKeyChar("q")
            print questions[index]
            #Create the message panel
            info_panel = hmd.addMessagePanel(questions[index], pos=(0,0,3))
            yield viztask.waitTime(2)
            #Remove the message panel
            info_panel.remove()
viztask.schedule(test())
Q2: Are there any ways to set visibility to be ON/OFF for the "addMessagePanel"?
Thank you in advance.
Makiko
