Old 06-09-2014, 02:37 AM
befl0 befl0 is offline
import vizcam
import time
from StopWatch import StopWatch
from Start import Start
from Line import Line
from Square180 import Square180
from CircledCylinder import CircledCylinder
from EightFigure import EightFigure
from Square360 import Square360
from ReverseGate import ReverseGate
viz.setMultiSample(4)
viz.fov(60)
viz.go(viz.FULLSCREEN)
#This code adds a ground for them to stand on.
env = viz.addChild('ground_grass.osgb')
env.collidePlane()
Light = viz.add(viz.LIGHT)
Light.position(0,1,0,0)
Light.intensity(1)
Light.spread(180)
view=viz.MainView
viz.phys.enable()
male = viz.addAvatar('vcc_male2.cfg')
male.state(6)
view.setPosition(0,0.3,0)
link = viz.link(view, male)
link.preTrans([0,-0.8,0.45])
link.setEuler([None,-20,None])
#link.preTrans([0,-0.12,0.35])
MOVE_SPEED = 5
TURN_SPEED = 60
viz.phys.enable()
def updateMove():
if viz.key.isDown(viz.KEY_UP):
view.move([0,0,+MOVE_SPEED*viz.elapsed()],viz.BODY_ORI)
elif viz.key.isDown(viz.KEY_DOWN):
view.move([0,0,-MOVE_SPEED*viz.elapsed()],viz.BODY_ORI)
elif viz.key.isDown(viz.KEY_RIGHT):
view.setEuler([TURN_SPEED*viz.elapsed(),0,0],viz.BODY_ORI,viz.REL_PARENT)
elif viz.key.isDown(viz.KEY_LEFT):
view.setEuler([-TURN_SPEED*viz.elapsed(),0,0],viz.BODY_ORI,viz.REL_PARENT)
pass
vizact.ontimer(0,updateMove)
rampe=viz.addChild('rampe.wrl')
rampe.setPosition(0,0,1)
rampe.setEuler(0,90,0)
rampe.collideBox()
rampe.disable(viz.DYNAMICS)
rFootBox = viz.add('box.wrl',scale=[0.1,0.1,0.1])
rFootBox.collideBox()
rFootBox.disable(viz.DYNAMICS)
rFootBox.enable(viz.COLLIDE_NOTIFY)
rFoot = male.getBone('Bip01 R Foot')
rFoot.lock()
rFootLink = viz.link( rFoot , rFootBox )
rFootLink.preTrans([0.05,0.15,0.18])
rFootBox.disable(viz.RENDERING)
lFootBox = viz.add('box.wrl',scale=[0.1,0.1,0.1])
lFootBox.collideBox()
lFootBox.disable(viz.DYNAMICS)
lFootBox.enable(viz.COLLIDE_NOTIFY)
lFoot = male.getBone('Bip01 L Foot')
lFoot.lock()
lFootLink = viz.link( lFoot , lFootBox )
lFootLink.preTrans([0,0.15,0.18])
lFootBox.disable(viz.RENDERING)
def collidBox(e):
global poleArray
if (e.obj1 == rFootBox) or (e.obj1 == lFootBox):
if(e.obj2==rampe):
view.collision(viz.ON)
view.gravity(9.8)
viz.collision(viz.OFF)
viz.callback(viz.COLLIDE_BEGIN_EVENT,collidBox)
This is my code. I put the ramp I create with sketchup in a zip folder.
File Type: zip ramp.zip (903 Bytes, 10439 views)
