Thread: viz.Theme()
Old 06-04-2014, 09:28 PM
I don't think the vizinfo panel has a theme option but you should be able to set the theme on the underlying vizdlg panel object. We don't have an example but can add this to our documentation to do list.
The forth value is alpha. From the Vizard IDE, press Alt + 1 to bring up a color dialog. Select a color to insert RGB values into your script.
