Thread: Mouse problem
Old 07-14-2005, 03:30 PM
steve steve is offline
thank you, that worked fine!
Now I want to switch between both navigation systems (old vizard native and new one). I imported the class as a Module, and it works fine, but what can I do to switch back and forth?
To stop the timer I used killTimer.
In an old thread I found that it was not possible to remove a callback function
(You wrote in http://www.worldviz.com/forum/showth...=stop+callback
There is no way to stop a callback. You can set a flag within your script and just ignore incoming events. However, we might consider adding this to the next release since it would not be too difficult to implement. )
Any suggestions? Is it now possible to remove callback functions?
I could use certain key-Commands, and only if the user presses that key, the new navigation system will be present...
Thank you.
