Old 05-27-2014, 05:59 AM
Are you now opening and running the demo from the Vizard 4 IDE? Make sure you're still running it using the Vizard 3 engine. From Vizard 4 you can select Script > Run with Vizard 3.0 if Vizard 3 is also installed on the machine.
If you're still having problems contact support@worldviz.com to request an updated demo.
