The problem I experience, which doesn't happen all the time, is that when I am editing my script and hit F5 to run it, the window in which you normally navigate around in becomes larger than usual, completely white, with the top information bar off the top of the screen, and unresponsive. Sometimes it works fine initially and crashes when I kill the window.
After I kill the window it says 'winviz.exe has encountered a problem and needs to close'.
If it's any use to you, the Error Report says:
Code: 0xc0000005
Flags: 0x00000000
Address: 0x000000006957ff22
But thanks for the nVidia reccie. I've never bought a video card before so it's good to get some expert advice!
