Hi all,
I have an application which can either run in single screen mode or three screen mode.
Single screen mode uses viz.MainView only and three screen mode, I use three custom windows.
My only problem is when I attempt to display text in the centre of the application. The parent of the text by default is viz.SCREEN. I attempt to reset this if I am in three screen mode to the centre screen.
Unfortunately, I don't see the text. I don't get errors either.
Screen Code:
# The following is also done for the left window and right window.
centreWindow = viz.add(viz.WINDOW)
centreWindow.setPosition(1.0/3, 1.0)
centreWindow.setSize(1.0/3, 1.0)
centreWindow.visible(0,viz.SCREEN)
centreWindow.fov(fieldOfView,aspectRatio)
centreView = viz.add(viz.VIEWPOINT)
centreWindow.setView(centreView)
def returnScreen():
	if(threeScreen):
		return centreWindow
		return False
 Here is my default text code:
	self.trialInstructions = "TEXT"
self.text = viz.addText(self.trialInstructions, parent=viz.SCREEN)
self.text.color(viz.WHITE)
self.text.setPosition(0.5,0.5)
self.text.alignment(viz.ALIGN_CENTER_CENTER)
self.text.fontSize(40)
self.text.visible(viz.OFF)
 During three screen mode, I run this code:
	if not(screen.returnScreen() == False):
	print otherScreen
	self.text.setParent(otherScreen)
self.text.visible(viz.ON)
 Can anyone see the mistake I am making?
