2d Map with Lines between points, help!
Hello everybody!
I'm a beginner in Vizard and I'm currently trying to create a visualization using a map.
Basically what I have is a 2d map and a set of points(from the map) I want to draw lines inbetween. The issue is that my points that I use for the lines are based on the texture coordinates of the map itself so that when I try to create vertices using these points they show up at the typical X, Y, Z coordinate system of Vizard instead of "on" the map.
My vision for this is to have the map and then see the lines in front of the map. Currently I have the map and then the lines elsewhere in the world.
Does anybody have any pointers / solutions for this? How would I solve this matter the best way? Is it possible?
M12
