Thread: bump mapping
Old 06-30-2005, 02:25 PM
I've attached a bump map demo. As I stated earlier, you will need a normal map and a diffuse map. The diffuse map is simply the regular texture map you want to apply to the object. The normal map is a texture which defines the normal at each pixel location of the diffuse map. You will have to generate this yourself. I'm not sure if 3dsmax will create it for you.
