Old 03-25-2014, 06:39 PM
Hi shivanangel,
Ambient is the correct slot for it. I'm guessing you're using white as the unoccluded color, correct?
If that's the case, the issue here is that the Vizard 5 shader expects lightmaps used in the slot to be centered on a middle gray. The values in the lightmap are multiplied by 2 before being multiplied by the values of the diffuse texture. This is similar to using the "Self-Illumination Scale" exporter option for the Vizard 4 approach.
For existing maps, this can be fairly quickly fixed by running them through a Photoshop batch process that halves their values (e.g. with Levels). For new baked maps, set the range to go from black to 50% gray instead of black to white.
