Old 03-12-2014, 01:58 PM
It's best to trigger the code using numpy while compiling the executable. Then, the files that Vizard needs to run the executable will be compiled in the executable. You can also add files manually, but chances are you're missing out on one or two 'obscure' files (a .dll file).
