This has nothing to do with your video format, resolution, etc. It is simply a matter of telling your codec to use ffdshow when playing back videos. If you installed klite, open the Codec Tweak Tool, go to Preferred decoders, and set which ever video format you want to use in Vizard to be set to ffdshow. If you're using Vizard 4, make sure to install/modify the 32 bit decoders and not the 64bit decoders. If you're using R5 Beta 64bit, modify the 64bit decoders.
Masaki
