Old 06-27-2005, 10:36 PM
Johannes Johannes is offline
One question and a rather unstructured protocol of this night:
1) if I do
host = "localhost"
addr = (host,PORT)
InSocket.bind(addr)
should it not bind the socket to localhost?
Should I not be able to access it by
telnet localhost 49213
Where Port is 49213
I also tried the current IP-Adress e.g.
telnet 169.254.148.117 49213
The following is more like a protocol, maybe not very useful...
Tried a lot around to get a connection between Java and your Socket.
Port is 49213
Why do I not get a reply when I do
Other Printouts:
COMPUTER_NAME OGL1
COMPUTER_NAME OGL1COMPUTER_IP_ADDRESS 169.254.148.117
I also tried (offline and online)
Only get connection failed.
From another Python Client I receive date: e.g.
from socket import *
# Set the socket parameters
host = "localhost"
port = 21567
buf = 1024
addr = (host,port)
# Create socket
UDPSock = socket(AF_INET,SOCK_DGRAM)
def_msg = "===Enter message to send to server===";
print "\n",def_msg
# Send messages
while (1):
data = raw_input('>> ')
if not data:
break
if(UDPSock.sendto(data,addr)):
print "Sending message '",data,"'.....<done>"
# Close socket
UDPSock.close()
From Java it works if I use
try
DatagramSocket sock = new DatagramSocket();
InetAddress server = InetAddress.getByName(host);
if (timeout > 0)
sock.setSoTimeout(timeout * 1000); // millisec
BufferedReader in = new BufferedReader(new InputStreamReader(System.in));
PrintWriter out = new PrintWriter(System.out, true);
String line;
while ((line = "hallo12") != null)
byte[] req = line.getBytes(), ans = new byte[1024];
DatagramPacket r = new DatagramPacket(req, req.length, server, port), a = new DatagramPacket(ans, ans.length);
but normal Client-Sockets do not work e.g.
Socket kkSocket = null;
PrintWriter out = null;
BufferedReader in = null;
InetAddress server_name = null;
try
//InetAddress server_name=localhost.byN;
//String COMPUTER_NAME = ;
String host = "localhost";
kkSocket = new Socket(server, 21567);
out = new PrintWriter(kkSocket.getOutputStream(), true);
in = new BufferedReader(new InputStreamReader(kkSocket.getInputStream()));
