Getting updated position
Hi all,
I am new to Vizard and still learning..
So, I am trying to move point of view from one position to another position using fluid movement (vizact.goto) and after the view point is moved to a new location, I need to get the the new coordinate of the view.
I wrote the following code:
viz.MainView.setPosition([10,2,3])
view = viz.MainView #grab the coordinate of main view
seq1 = vizact.goto([10,2,15]),3,viz.SPEED, pivot = [0,2,0], ori_mask = viz.BODY_ORI)
#execute action on key down
vizact.onkeydown(' ', view.runAction, seq1)
#get the current position after movement of view point
x,y,z = view.getPosition()
print "Your current position is", x,y,z
The problem is, instead of getting the position of view after the goto command ([10,2,15]), the getPosition always return the original position.
Is there any way that I can update the coordinate of the variable 'view' each time after an action is executed.
Thank you very much for all your help.
