Old 01-15-2014, 12:21 PM
masaki masaki is offline
Hello, thank you for trying out our Oculus Demos. We're looking into the issue you're having but in the mean time, can you make sure that you're running the Oculus at 1280x800 and make sure you're not cloning the Oculus with another display? I've noticed several times that when cloning on a laptop, the Oculus will display with the wrong aspect ratio thus resulting in a skewed projection. We currently do not force the Oculus to run at its native resolution upon launching our demos like other demos do so this may be the case. Can you give me your exact setup as well? Thanks.
